Joe X Posted August 11, 2018 Report Posted August 11, 2018 Two 6" round ports should be plenty. also you can do a port as follows to avoid a bad area ratio without increasing the port area itself which would require a longer port, more so if you are planning on low tuning :
image91 Posted August 13, 2018 Author Report Posted August 13, 2018 Was considering a pair of aero ports this time as well Joe, good call. If I do sub & a slot port centered it would be aesthetically pleasing & work out fine in terms of port area & ratio. Just some more work is all. Will consider the two options & keep you all updated. If I'm re-doing the box, will be going 28 Hz for sure = P
