DiBo Posted August 8, 2018 Report Posted August 8, 2018 Can anyone tell me what effects it will have on performance and sound? Box is actually for a Fi 15. Might put an X in there till I get the Fi. If I'm correct it's about 4.10ft³ with 62sq in port area. X calls for 4.25 and 68in port. Can anyone punch this in and post the results. Will be on 3k. Plenty power 33.5x21.5x17 Port is 15.5x4x31 15.5x2" 45° x4 in corners 1-45°@3.5"
Joe X Posted August 8, 2018 Report Posted August 8, 2018 The box itself would be 4.1 @ 32hz (3/4" wood) with 62 sqin port area, assuming a X15v2 on 3K (lil tricky), you would get 22.1 m/s max vent airspeed, so it would just work fine.
DiBo Posted August 8, 2018 Author Report Posted August 8, 2018 Sweet... Tricky part? How do I know how much power is optimal for a box?
Joe X Posted August 8, 2018 Report Posted August 8, 2018 You won't run out of port area just 3K needs some care for the sub.
DiBo Posted August 8, 2018 Author Report Posted August 8, 2018 I think the X is good for about 2k RMS. Should be ok. Thanks Joe. You da man.
