Bret Posted September 25, 2018 Report Posted September 25, 2018 I ran a single P2D2-10 at more than twice the rated power and it lasted quite a few months, but started sounding bad intermittently. When I inspected it I moved the cone with my hand and no rubbing. Both voice coils check out at appox. 2Ohms. I hooked it to a aaa battery and it functions. No visual defects. Anything else I can check before putting this in the dumpster? The amp is not the problem, I have used it for a year since with no problems. Thanks.
bmwking Posted September 25, 2018 Report Posted September 25, 2018 you could always rebuild it or turn it into a frankensub. would give you practice for those old school rockfords you just got
Bret Posted September 25, 2018 Author Report Posted September 25, 2018 I never thought of building a frankensub. That's a good idea. According to the specs on sonicelectronix there is no recone kit available, but it might be fun to try putting something unique together.
bmwking Posted September 25, 2018 Report Posted September 25, 2018 it definitely is. loads of good advice one here too. once you get it all broken down and separate the magnet from the basket you can get an accurate bolt pattern measurement and start shopping. join the 'custom subs & repair & parts' group on facebook to get a new coil that will fit at a much lower cost than psi or lordofbass (usually). i have a build thread i did of a frankensub to give you an idea of what to do.
Bret Posted September 25, 2018 Author Report Posted September 25, 2018 Awesome looking sub. That must have been fun to build. I appreciate the tip on the facebook group.
bmwking Posted September 25, 2018 Report Posted September 25, 2018 45 minutes ago, Bret said: Awesome looking sub. That must have been fun to build. I appreciate the tip on the facebook group. yeah it was great fun for sure, no prob
