Subwoofer enclosure help
Dillon Sahai
How much power are you going to be running?  What are the max dimensions you can fit in your vehicle?
Builds:
So here is a suggestion, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 4 ", figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
  • Who's Online   0 Members, 0 Anonymous, 1388 Guests (See full list)
