CrewCabBassHead Posted October 3, 2018 Report Posted October 3, 2018 So I just ordered 2 10" e series subs and I'm planning on putting them in my crew cab F250. There's not much room behind the rear seat. I've got 60" across the back, 8" deep at the bottom, tapering up to the top of seat ( where rear window begins) 24" tall. The guys on another forum are saying I have about 2 cubic feet to play with. Down for sound says one 10" ported would be tuned properly at 1.2 cubes @32-34hz. Just a few questions, I was thinking of doing one ported box behind the seat, and another sealed box under the rear seat. I have a Rockville 6000W / 1500 RMS 2 ohm amp coming in the mail as well. Can someone help me with designing the ported box? I'd love for it to hit deep. Here's my 10" sub specs. Thanks for all the help. http://www.sundownaudio.com/index.php/products/subwoofers-2/item/ev3-series
CrewCabBassHead Posted October 3, 2018 Author Report Posted October 3, 2018 E10 v.3 Sealed 0.5 ft^3 Ported 1.0 ft^3 Displacement 0.11 ft^3 Depth 5 5/8" Outside Diameter 10" Cut-Out 8 7/8" Recommended Tuning 32hz Recommended Port Area 16 in^2
ckeeler11 Posted October 3, 2018 Report Posted October 3, 2018 Doing 2 different boxes is a bad idea. you will have nasty peak where the sealed and ported alignments meet. The you can end up with nulls where they are not in phase. You are better off doing 1 in ported enclosure or 2 in a sealed.
CrewCabBassHead Posted October 3, 2018 Author Report Posted October 3, 2018 Ok I'm good with just one ported. I can build a box but how would I design the port? What would you recommend. Thanks for the help
speedygonzo1978 Posted October 29, 2018 Report Posted October 29, 2018 what year model f250 are we speaking of here?
BassMunky Posted October 29, 2018 Report Posted October 29, 2018 Make like mine one rectangles port each side on the bottom firing left and right. Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
