2 lithium 45ah enough?
paired with dual mechman 320s. running 8-9k ish?
6k, 2 600.4s, 1 150.2
audio will be mainly used with commuting. demo here and there. should I replace stock battery to lithium also? how many runs should I run from front to back? 1/0 welding wire probably. thanks.
More than enough
2000 Suburban 6 runs of 2/0
12 JBL Pro audo mids ,6 timpano audio tweets and 1 Prv compression horn per door
475ah of yin long LTOs
Triple 370 Amp Autotech Alts
mids amps 2  Crescendo Skyway 3ks
compreesion horn amp crossfire 800.4
Tweet amp Crossfire 2000.4
sub amp: 4 Crossfire XT 8ks
Subs: 8 18 in Crossfires in a 4th order
Best Scores at events…
163.5@38hz DBdrag  sealed on the dash… 164.3 outlaw…162.9 Meca headrest
33 minutes ago, zachhern said:
with an upgraded lithium up front? how many runs do I do ft to back?
an upgraded agm up front will work out fine (XS, FullRiver, etc.  deep cycle and good aH)
as for runs, figure at peak youll be pulling ~1000 amps.  that said, at least 4 runs of 1/0 should work out ok.  OFC is preferred to CCA for less voltage drop
  • Who's Online   0 Members, 0 Anonymous, 4925 Guests (See full list)
