Tway4231 Posted December 29, 2018 Report Posted December 29, 2018 Hey guy. I’m really struggling to understand if the sundown audio sa-12 with work for this box. Sundown audio SA-12 1.5-2.0 ft^3 @ 35hz Ported sub box Volume: 1.75 cu.ft net Vented Box Standard Port Configuration: 12.5"x2.5" x 24" Long Tuning: 33 hZ Does it matter that the hz is off by two? And if it does what could i do to make it match? Also on I saw that on the sundown audio website that it says .14 ft^3 displacement for a ported box. What does that mean and will this box still be ok for it. It seems to fix other wise. Subwoofer http://www.sundownaudio.com/index.php/subwoofers/sa-series Ported box http://subthump.com/Jeep-Wrangler-TJ-YJ-and-JK-Custom-Subwoofer-Enclosures-by-Subthump/New-20072016-Jeep-Wrangler-Single-12-Vented-Front-Fire-Sub-Enclosure-wAmp-Shelf-clone-1.html Thanks!
Bret Posted December 30, 2018 Report Posted December 30, 2018 If it were me I would tune it to whatever I liked and not follow the recommended 35hz. .14 ft3 is how much space the sub uses so you would subtract that number from the box volume to get your actual volume. In your case it would end up being 1.61 ft3 with the sub installed in it.
