youdoofus Posted January 24, 2019 Report Posted January 24, 2019 Been tossing the idea of dash pods for a 4" and a tweet for a while now, but wasnt sure how you guys go about fabbing them. From what i can tell, the base of the pod matching up with the dash is the hardest thing. Do you recommend tape the dash and use body filler to get the shape? The rest of it should just be framing up the insides of the pod and then glassing it, covering with vinyl and a grill of some sort.
dolarbilz Posted January 24, 2019 Report Posted January 24, 2019 Tape dash and surronding areas with blue tape.lay foil over tape ..build a base using fiberglass on top of that..build a nice thick base..keep in mind you need to fasten it to dash some way..thread inserts in dash might be good..you really need to think creative.
youdoofus Posted January 24, 2019 Author Report Posted January 24, 2019 2 hours ago, dolarbilz said: Tape dash and surronding areas with blue tape.lay foil over tape ..build a base using fiberglass on top of that..build a nice thick base..keep in mind you need to fasten it to dash some way..thread inserts in dash might be good..you really need to think creative. gotcha. thats kinda what i figured. thanks man
