reedal Posted March 6, 2019 Report Posted March 6, 2019 Sub up port back tends to yield best results in tahoe/Yukon. Port should be at least one port width away from lift gate. That distance can affect frequency response some. Four 18's behind second row is doable, but you won't have optimal airspace. I believe when Steve meade did his box he even said he knew it wouldnt be the best but he did what he could to make it work. You also need to figure out amp and battery placement. I would do that first, then measure how much enclosure space is available. He made a "tub" battery rack in the spare tire area, which required cutting and welding, then put the amps under the enclosure SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
