kapicarules Posted February 6, 2019 Author Report Posted February 6, 2019 So basically as long as my grounds are solid and the big 3 has been completed with bigger wires I should push 1kw no problem on the stock alternator.
XSVTOYZ Posted February 6, 2019 Report Posted February 6, 2019 11 hours ago, kapicarules said: So basically as long as my grounds are solid and the big 3 has been completed with bigger wires I should push 1kw no problem on the stock alternator. should be nice w/o straining too hard
MrSkippyJ Posted February 6, 2019 Report Posted February 6, 2019 Regular headlights react to the smallest amount of voltage fluctuation. Alternators don’t produce power immediately, it takes a small amount of time to get the power going, even if you have more than enough alternator power. Batteries will help smooth that out but you will still have voltage fluctuations. Different type of headlights are the best way to deal with dimming, but don’t confuse dimming with weak electrical if you know you have enough of it. You are probably ok with stock alt and a nice AGM battery. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
kapicarules Posted February 6, 2019 Author Report Posted February 6, 2019 6 hours ago, MrSkippyJ said: Regular headlights react to the smallest amount of voltage fluctuation. Alternators don’t produce power immediately, it takes a small amount of time to get the power going, even if you have more than enough alternator power. Batteries will help smooth that out but you will still have voltage fluctuations. Different type of headlights are the best way to deal with dimming, but don’t confuse dimming with weak electrical if you know you have enough of it. You are probably ok with stock alt and a nice AGM battery. I'm goin led for sure.
