tbeats Posted March 14, 2019 Report Share Posted March 14, 2019 With a Rockford t1500bdcp @ 2ohm said rms is 1626, subs two P3 15's d2 in a sealed 5 cubic net sealed enclosure. With that setup what would be the best gain overlap 0db or maybe -2.5db? Sealed box range is 1.5 to 3.0 cube per I'm at 2.5 per dont wanna really chance over power and kill them. Any help would appreciate. Quote Link to comment Share on other sites More sharing options...
tbeats Posted March 14, 2019 Author Report Share Posted March 14, 2019 Also the Rockford PEQ remote is installed currently set to 0, was told would be needed because running a sealed enclosure but not using until amp is set correctly. Quote Link to comment Share on other sites More sharing options...
Joshdashef Posted March 14, 2019 Report Share Posted March 14, 2019 5 cubic net sealed box? Seems pretty big for those subs Those P3s call for 1.58 cubes per, so 3.16 cubes, +/- some if you want to have the suspension move easier, but I think 5 cubes might cause them to bottom out especially with over rated power. Quote SMD Tool Map (2022): https://www.stevemeadedesigns.com/board/topic/220267-smd-tool-map-2022/ My Port Size Calculator (in progress): https://www.stevemeadedesigns.com/board/topic/217087-port-size-calculator-in-progress/ Common Port Walls for a Slot Port: https://www.stevemeadedesigns.com/board/topic/217076-common-port-walls-why-it-matters-to-your-box/?tab=comments#comment-3240313 Link to comment Share on other sites More sharing options...
tbeats Posted March 14, 2019 Author Report Share Posted March 14, 2019 16 minutes ago, Joshdashef said: 5 cubic net sealed box? Seems pretty big for those subs Those P3s call for 1.58 cubes per, so 3.16 cubes, +/- some if you want to have the suspension move easier, but I think 5 cubes might cause them to bottom out especially with over rated power. That was what Forrest at Rockford recommend when we called him was 4.5 to 5 cube and I personally told him the t1500bdcp so was he thinking set the gain with 0 overlap I really wish I had asked him. Quote Link to comment Share on other sites More sharing options...
Joshdashef Posted March 14, 2019 Report Share Posted March 14, 2019 (edited) 4 minutes ago, tbeats said: That was what Forrest at Rockford recommend when we called him was 4.5 to 5 cube and I personally told him the t1500bdcp so was he thinking set the gain with 0 overlap I really wish I had asked him. He must have had a reason for telling you that, can't say I know why. Safer side would be the 0 overlap so I would give that a try, and if you don't hear any bottoming out then you could keep it or tune it with -2.5 overlap and check for any bottoming out once again. Edited March 14, 2019 by Joshdashef Quote SMD Tool Map (2022): https://www.stevemeadedesigns.com/board/topic/220267-smd-tool-map-2022/ My Port Size Calculator (in progress): https://www.stevemeadedesigns.com/board/topic/217087-port-size-calculator-in-progress/ Common Port Walls for a Slot Port: https://www.stevemeadedesigns.com/board/topic/217076-common-port-walls-why-it-matters-to-your-box/?tab=comments#comment-3240313 Link to comment Share on other sites More sharing options...
tbeats Posted March 14, 2019 Author Report Share Posted March 14, 2019 4 minutes ago, Joshdashef said: He must have had a reason for telling you that, can't say I know why. Safer side would be the 0 overlap so I would give that a try, and if you don't hear any bottoming out then you could keep it or tune it with -2.5 overlap and check for any bottoming out once again. Would you use the subsonic filter on the amp it's fixed 28db 12db slope, everything I see also the smd cc1 manual says 15's dont need sealed but I'm looking at the over power the subs will get would it hurt? Looking to get as deep as possible. Quote Link to comment Share on other sites More sharing options...
tbeats Posted March 22, 2019 Author Report Share Posted March 22, 2019 Went with 0db track since the amp is over power 1500+ at 2ohm. was previously set at -5 and was way to much. In the future we may try -2.5db track but that much power over rms with Potential clipping feels scary. Quote Link to comment Share on other sites More sharing options...
