DiBo Posted March 24, 2019 Report Share Posted March 24, 2019 Your port area will be rather small if you bring it down to 2.5 wide. The tuning will definitely go down tho. Link to comment Share on other sites More sharing options...
W3BL4Z3D4NK Posted March 24, 2019 Author Report Share Posted March 24, 2019 1 hour ago, DiBo said: Your port area will be rather small if you bring it down to 2.5 wide. The tuning will definitely go down tho. Will it cause port noise? Or how will it negatively impact the build? Link to comment Share on other sites More sharing options...
DiBo Posted March 24, 2019 Report Share Posted March 24, 2019 1 hour ago, W3BL4Z3D4NK said: Will it cause port noise? Or how will it negatively impact the build? With 1000 watts I seriously doubt you get any port noise. You'd be around 34in² port area. I can't comment on how it'd sound but those subs do pretty well with a proper enclosure. Build it. You might like it. You'd get more output with the original specs tho. Link to comment Share on other sites More sharing options...
k58.cross Posted August 16, 2019 Report Share Posted August 16, 2019 Hey this brings up a question on power vs. port area. To calculate port area should you use nominal power or power after impedance rise at some frequency? Link to comment Share on other sites More sharing options...
Triticum Agricolam Posted August 16, 2019 Report Share Posted August 16, 2019 4 hours ago, k58.cross said: Hey this brings up a question on power vs. port area. To calculate port area should you use nominal power or power after impedance rise at some frequency? Nominal power. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds: Link to comment Share on other sites More sharing options...
