Triticum Agricolam Posted April 3, 2019 Report Posted April 3, 2019 10 minutes ago, 06manvan said: What length of 6" port I guess would be my next question? 26" long. Or if you went with two 4" ports they would need to be 22" long. Either option would tune you to about 34 hz. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
06manvan Posted April 3, 2019 Author Report Posted April 3, 2019 Yeah. I messed up. Its 2.1 cubic feet. Deepest measurement is 24". What's my options after my screw up. Cubes seems a little on the small side
Triticum Agricolam Posted April 4, 2019 Report Posted April 4, 2019 2 hours ago, 06manvan said: Yeah. I messed up. Its 2.1 cubic feet. Deepest measurement is 24". What's my options after my screw up. Cubes seems a little on the small side Do you have more space for a larger box? After port displacement you are probably going to be around 1.7 cu ft and its going to be REALLY hard, if not impossible, to get a port long enough to get your tuning where you want it while having enough port area. If it were me, I'd start over and build a slot ported box with the proper port area and tuning rather than finish a box that its likely will always have problems. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
06manvan Posted April 4, 2019 Author Report Posted April 4, 2019 I could, I can go deeper and taller. My problem with designing one with the calculators is I have a kerfed front. what should be a cubic feet and port length and diameter I should shoot for?
Triticum Agricolam Posted April 4, 2019 Report Posted April 4, 2019 58 minutes ago, 06manvan said: I could, I can go deeper and taller. My problem with designing one with the calculators is I have a kerfed front. what should be a cubic feet and port length and diameter I should shoot for? I can help you with a design, what sub are you running? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
06manvan Posted April 4, 2019 Author Report Posted April 4, 2019 Skar sdr 12. At 600 rms. Would like to do a circle port if possible
mothra Posted April 4, 2019 Report Posted April 4, 2019 do a 4" aero port, tune lower like 28-30hz. you'll have a wide playing range and get low. if nothing changes, nothing changes You don't know what you don't know, till you don't know
06manvan Posted April 4, 2019 Author Report Posted April 4, 2019 10 hours ago, Triticum Agricolam said: I can help you with a design, what sub are you running? I guess if you can give me a cubic foot goal with proper aero port sizes I can work with that if it isn't to much to ask. Thanks
