PeterG Posted April 18, 2019 Report Posted April 18, 2019 I currently use a standard inline fuse, and am considering moving to a circuit breaker, similar to these: https://www.amazon.com/Stinger-SGP90300-300-AMP-Circuit-Breaker/dp/B00TPKZUV0 https://www.amazon.com/dp/B07C3D19TD I would take two 1/0 cables from the battery to a DS18 dual reducer (https://www.amazon.com/DS18-DPIV1-Gauge-Reducers-Offset/dp/B06XHRVZ4C/), than into the 300A breaker, Than another DS18 dual "reducer" to expand back to two 1/0 cables, than out to the amps/etc. What are you all using? I see there are some negative reviews on some of the breakers... Thoughts? Also, I was looking for some type of remote-trip breaker to use with an Emergency Stop button, but cant find anything (a breaker to put on my main amp/stereo power cable that can be tripped remotely with a low-voltage E-Stop button mounted near the driver). Does anyone else do an E-stop circuit, or does everyone just wire in a fuse an forget about it?
Joshdashef Posted April 18, 2019 Report Posted April 18, 2019 From what I have heard those circuit breakers will get easier and easier to trip the more you switch them on/off. Eventually causing problems with the amps, etc. I'd steer clear of them imo but if you must have a quick disconnect there might be other solutions that offer a more reliable experience long term. If everything is fused properly I see no reason for a quick disconnect though, unless you plan to work around the cables a lot under the hood. SMD Tool Map (2024): https://www.stevemeadedesigns.com/board/topic/226545-smd-tool-map-2024/ Great Box Bracing Examples: https://www.stevemeadedesigns.com/board/topic/202148-best-way-to-brace-a-box/?do=findComment&comment=3055002
