I am setting the gains with a dd1. My head unit clips at max volume(38). Factory speakers sound like butt so I only go to 32. When I try to set the bass level on the Lc2i the max light comes on way before the dd1 distorts.  So my question is should I just set the Lc2i settings right before the max light comes on or go off the dd1? My head unit does not roll off(as far as I know/can hear). I have the threshold turned all the way up. Everything I have read says to do that if radio doesn’t roll off. Any help would be great thank you.
Sat gain on amp and lc2i to minimum.
Plug DD-1 into the lc2i with rcas.
Turn you volume on head unit to max volume before clipping/distortion.
Turn the lc2i up until either the DD-1 light comes on or the max light on the lc2i. Stop when either light comes on and turn back slightly just enough to make it go out.
Then set gain on the amp with the DD-1 as usual.
