Joshdashef Posted May 23, 2019 Report Posted May 23, 2019 Could I soldier on my own ring terminals in place of the jumper alligator style clamps that come with this charger so I can use it as a permanent installed piece. That way I can just hook up an extension cord and lock up the car overnight ? Pic SMD Tool Map (2024): https://www.stevemeadedesigns.com/board/topic/226545-smd-tool-map-2024/ Great Box Bracing Examples: https://www.stevemeadedesigns.com/board/topic/202148-best-way-to-brace-a-box/?do=findComment&comment=3055002
melvinhob Posted May 23, 2019 Report Posted May 23, 2019 If you are planning on leaving it permanently installed I don't see any reason why you couldn't. The alligator clips are just a means of temporary connection, if you will be leaving it installed the ring terminals will be your permanent connection and serve the same purpose of delivering current to your batteries.
Joshdashef Posted May 23, 2019 Author Report Posted May 23, 2019 4 hours ago, melvinhob said: If you are planning on leaving it permanently installed I don't see any reason why you couldn't. The alligator clips are just a means of temporary connection, if you will be leaving it installed the ring terminals will be your permanent connection and serve the same purpose of delivering current to your batteries. Okay sweet thanks just like to double check ideas on here sometimes SMD Tool Map (2024): https://www.stevemeadedesigns.com/board/topic/226545-smd-tool-map-2024/ Great Box Bracing Examples: https://www.stevemeadedesigns.com/board/topic/202148-best-way-to-brace-a-box/?do=findComment&comment=3055002
