Black24s Posted May 28, 2019 Report Posted May 28, 2019 I'm in the process of building an enclosure for a Skar VVXv3 12 and I was wondering if I tuned too low. The internal volume is 2.96 after bracing and sub displacement with a slot port area of 2"x14.5" (29 sq inches )and the port length is approximately 32" which puts me around 26ish hz. Is that too low ? I do not have have the top on the enclosure yet so I have the option to change it while I'm ahead.
SnowDrifter Posted May 28, 2019 Report Posted May 28, 2019 Is it one driver? ~3cuft sounds a bit on the large side if so. What's your intended use case for this? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Black24s Posted May 28, 2019 Author Report Posted May 28, 2019 Yes it's one driver , the enclosure is 2.22 and the port area is .74 which gives me the 2.96. It will be for an extended cab f150
Triticum Agricolam Posted May 28, 2019 Report Posted May 28, 2019 If your port volume is .74 cu ft then you need to subtract that to get the net volume. Which it sounds like is 2.22 cu ft, so your tuning would be higher. Assuming the box is built you can just play test it and find out what your tuning REALLY is using sine wave tones and watching cone movement. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
