Guest Nismofreak Posted December 4, 2006 Report Posted December 4, 2006 Is their any way to get rid of ground loop? Quote
scratchy Posted December 4, 2006 Report Posted December 4, 2006 ground loop isolator and also get rid of some of your highs while your at it Quote then im rambo bitch
Ray Posted December 4, 2006 Report Posted December 4, 2006 are you sure you have a ground loop problem? what did you do to track it to a ground problem?? what have you isolated it to? how did you identify is was induced noise? Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
Guest Nismofreak Posted December 4, 2006 Report Posted December 4, 2006 from speakers. It makes a buzzing noise and the whenever I turn on the blinkers it does a noise in the speakers Quote
Ray Posted December 4, 2006 Report Posted December 4, 2006 what equipment do you have? amps? do you have an aMP on the highs? what car? it sounds like your using a neg. dimmer for a ground.. Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
Guest Nismofreak Posted December 4, 2006 Report Posted December 4, 2006 It might even be the ground wire.The wires which I own are by boss audio Quote
Ray Posted December 4, 2006 Report Posted December 4, 2006 what? no ....your deck ground wire man.. name the equipment you have.. like i asked Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
Guest Nismofreak Posted December 4, 2006 Report Posted December 4, 2006 I had soundtrack install my equipment. 4 boss audio 6 components, 2 boss audio subs, 3 boss audio amps and one sony deck. Quote
Ray Posted December 4, 2006 Report Posted December 4, 2006 ok and always had a problem? or just all the sudden? Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
