1885199158_Subbox2019SD8s.jpg.53fce3772e36b55a05db63bff995380c.jpgWhat size and length port or ports should be used to tune the 3 Sundown E8 V.6 D2's in a common chamber to the recommended 32 hz?  I can do one on each end or a single round vent up to 3" in diameter.
Another possibility is building a slotted vent either single or double exiting out the sides?  The height of 6" could be increased or decreased which of course would change the bottom internal width.
I will most likely be adding bracing which will drop the internal volume down closer to around 2.0 cubic ft.
Appreciate your help ahead of time!
  • Who's Online   0 Members, 0 Anonymous, 2413 Guests (See full list)
