Are these Horn or Super tweeters?
02 - TJ Sport
Rockford Fosgate - Punch Pro 1.5" 4-Ohm Tweeter PP4-T
I am specing something for a Jeep TJ build.
I was thinking of running these in the front in 5.25"(modified) brackets.
I find that regardless of what goes in those 2 front holders the mids / bass is going to just be lost there with this build anyways its a very closed up area something overpowering will need to be there for it to come through.
I have heard horns can mess with your sound via beaming im just wondering if these might be similar to that? or just super loud tweeters @ 50-rms?
I am running a "Sony Mex-xb100bt" Deck that can output 42W RMS (100W total - Each channel).  I was thinking because i'm likely going to have quite a large soundstage in this jeep off a Rockford Fosgate - T1000X5ad Amp with 4 channels x 100W-RMS for full range and 600RMS for a sub out, these may be a good choice right in the front for bringing the soundstage forward.
I was also debating using the rear outputs off that same Deck to do possibly 2 more mounted at the very back on my Sub box which will be fixated to the swing out tailgate running a Rockford - Power T1 Shallow 12 sealed .
On the Rear of the jeep will run Punch Marine 8" Wakeboard Tower Speakers - Black PM282W-B - and i was thinking maybe doing on the sound bar which can hold 6.5" max speaker sizes and since its mid vehicle and mid might work ok there on a front or rear output  with Punch Pro 6.5" 4-Ohm Midrange PPS4-6 im still unsure of those would fit via magnet size though i need to measure the soundbar.
A Lot of this decision relies on those tweeters being less of a horn .. but it still might work like that too.
What do you think about such a configuration will it be off?
PS*
I figured i should add i have my reasons for doing this build in entirely Rockford fosgate speakers and i know its limiting .
Those are the tweets to go with their pro mids. I have a 01 tj and used versa pods and mod pods to bring my sound forward. Both with coaxials in them. Sounds really good.
Yea im running kicker Coaxials in the jeep atm off the same deck "42-rms per channel 100W MAX" and to be honest once its howling down the road i have to turn that deck up far to much and everything else is reflected in that.
at a stop its super loud but on the road it is just weak unless cranked.
Those tweeters i feel match up with the mids for the soundbar but the rest of what i typed out wont lack either.
versa mods and pod mods are ok but i feel unnecessary tbh , with the sub - the 6.5" 100W-RMS x2 mids and the rear 8" full range pods i think mid base will be the least of my concerns.
This is a build for me but also going to be a bit of a demo.
I have the same deck and what 02-TJ Sport is saying is definitely true. Even though it's 42w/ch, it has very little overhead compared to a dedicated amp, and I think that's due to the small wires you have to attach to (even if you're running a dedicated line from the battery you're still connecting it to a puny 16ga molex connector.)
The 5amp RCA outputs are nice, though.
  • Who's Online   0 Members, 0 Anonymous, 1110 Guests (See full list)
