Enlcosure design for 4 12s sealed
Ohmmm
2 minutes ago, Ohmmm said:
4 doors and trunk have about 90sqft of deadener. What do you mean by sealing them?
If you want to significantly increase midbass response, you're going to want to seal off the large access hole in the interior door panel to turn the door cavity into what is essentially an enclosure.
BYTizzle bit of a squeeze, eh? Verrrrry little increase in outside box dimensions is available. I'd say maybe an inch extra on width and depth without building it inside the trunk. If I did build it inside the trunk, which I'd rather not do, I have 41.5 inches of width well to well.
