Csaldivar78 Posted October 20, 2019 Report Posted October 20, 2019 So I’m new to building sub set ups off factory radios and trying to decide which will be best for what I’m doing and I’m trying to decide between a epicenter or the lc2i, if you’re using either what do you love what do you hate about each
AaronT Posted October 20, 2019 Report Posted October 20, 2019 Answered in other thread. The epicenter is not going to give you LOC You'd need the lc2i and epicenter to use the epicenter
Csaldivar78 Posted October 20, 2019 Author Report Posted October 20, 2019 59 minutes ago, AaronT said: Answered in other thread. The epicenter is not going to give you LOC You'd need the lc2i and epicenter to use the epicenter Ah okay, I was Under the impression it was the same thing
AaronT Posted October 20, 2019 Report Posted October 20, 2019 Know the epicenter only accepts low level inputs in other words the only will take RCA jacks from your head unit wire to amplifier and restore base You need high-level input capability to turn into a low-level input that's what the lc2i is for or you can even use the matrix + 6 channel line driver what you can go in one input to turn it into three front rear and sub and also have the ability to boost voltage pretty high to or you can even just use one of their new badass amplifiers that incorporate lc2i directly in the amplifier
paidnfull Posted October 22, 2019 Report Posted October 22, 2019 They make an epicenter with high level inputs. The "plus" and "indash" model both have them.
