jnasty Posted October 29, 2019 Report Posted October 29, 2019 Hey guys, so i'm doing the finishing touches on my install and it came time to power everything up. When I powered up the sub amp (4000se), the fans went on max as if i were full tilt on the volume. realized the protection led was flickering red/green. I power cycled the amp and the logo started to flash. it did (flash, pause, followed by 5 more flashes.). power cycled again, and the fans went on again... i get either the LED flashing or fans on max. Hooked up a 8" mid-bass ive got and it sent the cone so far outward, it came out of the gap. realized ive gotta meter the amp, ive got 13.2v in & the speaker outputs are giving me 97.5V DC out??!?!?!??! The last time this amp was used, it smoked a sundown nsv4 18. Could a short on the sundown coil fry the amp?? Arent amps protected from situations like this, especially top on the line amps?? Vehicle: 2002 Ford Escape Electrical: 275A Singer, 160ah XS/Yinlong lithium, 2,000farad XS Supercaps Head Unit: Apple iPad Hi-Res Passthrough Topping d10s Speakers: {ACTIVE} - (4) Arc Audio RS 6.0, (2) Arc Audio RS 4.0 & (2) Arc Audio RS 1.0 Sub Stage: (2) TC Sounds LMS Ultra 5400 18" Amplifiers: ARC Audio - (4)4200SE(comp modded, (2)4000SE Processing: Helix DSP Pro W/ Dash Mounted Director
jnasty Posted October 29, 2019 Author Report Posted October 29, 2019 Popped the cover to find one led red & the other blue... Red is bad I'd guess Vehicle: 2002 Ford Escape Electrical: 275A Singer, 160ah XS/Yinlong lithium, 2,000farad XS Supercaps Head Unit: Apple iPad Hi-Res Passthrough Topping d10s Speakers: {ACTIVE} - (4) Arc Audio RS 6.0, (2) Arc Audio RS 4.0 & (2) Arc Audio RS 1.0 Sub Stage: (2) TC Sounds LMS Ultra 5400 18" Amplifiers: ARC Audio - (4)4200SE(comp modded, (2)4000SE Processing: Helix DSP Pro W/ Dash Mounted Director
CrackFactory Posted October 29, 2019 Report Posted October 29, 2019 Send it to the Amp Lab. www.theamplab.net It's definitely broken if you get DC voltage at the speaker outputs.
