Where can I get some MDF rings cut ?
fishchris1
I need several large rings cut from 3/4" MDF. Like 5 or 6 of one size, and 2 of another. And while I'm at it, I suppose the same place / person with the right equipment, could probably cut me a bunch of 45 degree strips to round some inside corners on an enclosure....
Well, I will already have the wood... 19 1/2" squares of 3/4" MDF... Seven of them.
I will need 7 rings...
5 will need to be 14" inside diameter, and 17 1/2" outside diameter... So 1 3/4" wide.
The other two need to also be 17 1/2" outside diameter, but I need to get back home to get the inside measurements from my subs (the outside edge of the surround). To tell you the truth, I might only need 1 of these if somebody has a little 1" MDF or two pieces of 1/2".... But I need to measure the height of my surrounds once more also.
  • Who's Online   0 Members, 0 Anonymous, 1450 Guests (See full list)
