Can somebody check my calculations before gluing the baffle?
CorNut
33 minutes ago, CorNut said:
The box needs to be small for this vehicle and the SA has been sitting around for a while, I figured wth. Would you suggest pairing the box/amp with a different sub? I went to finish it today but it turns out I don't have the right size hole saw for the terminal cup so I ordered a different sized one. Being a single ported 10 I decided it's ok to use a terminal cup. It needs to sit flush against the seat and a terminal cup is the only way. I don't mind putting a different sub in there if I'll be doing the SA a disservice. Before port displacement it'll be ~1.08 cu ft and the port will be 28" long.
Now it's time to go learn about box rise
No, you have it so run it. I'm just saying for future reference. But I have always been a big box person so I may be biased.
I have ran multiple different subs is various sizes boxes and have always preferred a larger than recommended box. May just be my personal tastes.
I always try to cram the largest box I can fit in any given space. Then based on the airspace I have available I pick my subs. Sometimes you have .5 cubes to work with, sometimes 16 cubes... just depends
05 TL build log SOLD
I'll throw it in and run with it then. I appreciate your help. Btw in my last message I meant 1.08 before woofer displacement, not port displacement but I'm sure you knew what I meant. Thanks again
  • Who's Online   0 Members, 0 Anonymous, 660 Guests (See full list)
