I have a 1994 Chevy Silverado C1500. I replaced all the 4x6's, added an amp, with headunit. As of now I have the amp connected straight to the battery. My voltage on my dash is 13 volt area but turning on my headlights or blinkers drops the voltage to 12. I have a factory alternator for the mean time. I am looking into adding a secondary battery for installing 2 sundown audio subs. Could I connect both the amp for the speakers and amp for the subs, to the secondary battery or will that be too much of harm on the secondary battery?
Yes, you can run all amps off the second battery.  It is how it should be done anyway imo.  When you add a second battery you just increase your battery bank size.  All the power is connected in series.
As for your voltage drop i would suggest going over the entire electrical system.  1 amp power 4x6 speakers should drop the voltage that bad, sounds like a bad connection.  Make sure you grounds are metal to metal.
5 hours ago, Justin.Obs said:
I have 1/0 for the big 3 upgrade just haven't done it yet
That will be necessary for the sub set.  Get it done and see if that helps.
These trucks have very shitty stock electrical . Blinkers drop voltage even. Make sure along with the big 3 u run a new 1/0 from battery to the fuse box under the hood. It will solve alot of grief , all I did ( before I did a complete upgrade ) in my gf Yukon was from battery to fuseblock and power was alot more stout, very good after complete upgrade. You HAVE to upgrade the alternator in these things, in a pickup I think stock alt is like 90amp. I u have access to other gm trucks, see if you can get one out of a suburban or van and the alts range from 115 to 130a...or one off a 2004 suburban is a 160a but u have to change the plug.
  • Who's Online   1 Member, 0 Anonymous, 1666 Guests (See full list)
