What fuse size to use?
I have a taramps MD 8000.1 and have a single run of 3/0 welding wire . A second run of 3/0 coming soon but gonna use a single run for now. The 3/0 is rated for 450a at 100' ( I believe thats what I read) the amp will pull almost 900a at full tilt, which it'll almost NEVER see, one because power is rated at 2 ohm, initial wiring on subs is 2.67 and after rise amp will be seeing roughly 4 ohms . I have 250a fuses and 500a fuses ( accidentally ordered them a while back ) . If the wire is rated 450 at 100' and my longest run is like 15' , a 500a fuse should be sufficient wouldn't it? Let me know if I'm wrong and I'll order appropriate fuses. Thanx in advance.
39 minutes ago, CrackFactory said:
I run an md8000.1 1 ohm. I have 300a fuses. I have not popped one yet.
My box rises from 1 ohm to 3.6 and I've clamped 2600 watts from it.
Ok, guess I'm gonna order sum 300 or 350s then...think 500 is too much tho? I got the 2 ohm version of the md8k, so at 4ohms I should get 5k out of it.
  • Who's Online   0 Members, 0 Anonymous, 1065 Guests (See full list)
