How Big Of A Battery Do I Really Need?
alright...so im starting to build a new setup. heres the specifications:
1. 4 12" L7's
2. 2 crunch pzi3000.1 ( 1500 rms each)
3. 200-250 amp alternator
4. 0 gauge
Im trying to figure out how many amps i need in a battery....its gonna be about 3000 watt rms system and the battery is going to be strictly to the system in the back. Im looking at a kinetik battery and im trying to decide which one to get....what is the least amount of amperage that i need to get for a battery? also how would you recommend setting this battery up? connecting it to the front battery through zero gauge and then grounding it? I'd appreciate some help from you guys.
2000 Eddie Bauer Expedition:
Alpine CDA 9883
2x 18" DC lvl 4 D2
10.7 cu ft box 33hz
knu 1/0 wire
amp: Kicker ZX2500.1
Kinetik
I would go with a Powermaster D3100 or a Kinetik HC2400 the more the better
I know that those will do the job (and more), but would the kinetik 1400 be enough??
Alpine CDA 9883
2x 18" DC lvl 4 D2
10.7 cu ft box 33hz
knu 1/0 wire
Kinetik
not if you want to have full power on tap kinetik rates their batteries by wattage =battery# so if you have 3000 then you need ???????
o 4 real? see...i didnt even kno that....well i guess the smallest i could do is one 2400 then, i really didnt want to spend that much money on a battery, but i guess i need to lol
Alpine CDA 9883
2x 18" DC lvl 4 D2
10.7 cu ft box 33hz
knu 1/0 wire
Kinetik
Could he ground the battery that's going to be in the back, and the two amps to one spot or is that bad?
2008 Chevy Impala (undercover cop style)
Setup in the makings
he could ground it to a bus bar (?). they have like 2+ bolts on it so you dont have to use random ground points on the car
Yeah I was thinking like that instead of grounding them to three seperate areas. But I was wondering for my own sake if that is possible. Like grounding the battery and the two amps to one spot wouldn't cause problems now would it?
  • Who's Online   0 Members, 0 Anonymous, 557 Guests (See full list)
