Vinny415 Posted March 29, 2020 Report Posted March 29, 2020 So I recently added a second mono amp same make and model to match what I already had. I have two subs. Each sub is wired to each amp. The amplifiers have bass boost knobs. When I turn both knobs up I lose output to my subs. Why is this happening. Each amp gain was set using a multimeter (can’t afford an SMD DD-1 right now). Each amp should be pushing at least 750w rms at 1-ohm. Which is what was certified on the dyno, but like I said before, when I turn both of the amplifiers bass knobs up, it hits less than when my subs were running off 400w each!
AaronT Posted March 29, 2020 Report Posted March 29, 2020 Cuzz your electrical can't support the current demands
Vinny415 Posted March 30, 2020 Author Report Posted March 30, 2020 I drive a 2015 Camaro SS and the alternator is sufficient. I am running 0 ga power to distribution block, then 4 ga to each amp. 4 ga grounds to grounding block which is then grounded with 0 ga to a good ground. Checked with multimeter. I smoked one sub earlier this week because I set gains without bass knobs installed and turned them up too high. Reset the gains to proper voltage with knobs turned all the way up so I could eliminate the possibility of turning up too high.
Vinny415 Posted March 30, 2020 Author Report Posted March 30, 2020 UPDATE ::: So after a little research, I remembered watching a video by Mark at CAF talking about phasing and polarity. So I pulled it up again and saw that a common fix was that manufacturers sometimes install the wrong polarity terminals. So positive and negative is flipped. So I tried flipping my speaker wires to one of my subs and BOOM!!! Now my subs are hittin like they’re supposed to! Now if I could figure out a way to build a ported box for both 12s to fit in my small ass trunk and still have space for stuff...
