High pitch tone coming from tweeters
DokJ
On 4/13/2020 at 1:07 PM, DokJ said:
OK moved the power wire to the battery. Still have the noise.  Here's a pic of the ground and the newly moved power wire.  The reason I don't have the wires and fuse holder, etc mounted is because I'm still testing things and was waiting to do all of that until I got everything running right.
That’s a bad ground spot. You see you grounded it on a little piece of metal spot welded to the chassis. Ground it straight to the chassis. If you can’t find a spot to nut and bolt then use 3 self drilling screws with washers to secure the ground. One in the middle of the ring terminal and one on each side. It has to be a hard ground on the chassis, not metal connected to the chassis by welds or nuts and bolts.
:guido:
  • Who's Online   0 Members, 0 Anonymous, 1154 Guests (See full list)
