What is the cubic feet of my box???
BiGSt3v3
This is my very first time building a box and I'm having trouble figuring out my box volume. I think it may be too big. Here is all the information on the box and I would be so grateful if someone could calculate my box volume for me.
The wood I used is Birch Plywood 3/4 thick. Top is double baffled 1.5 inches
Outer Dimensions - Width 35.5in
                                     Height 19in
                                     Depth 14.5
Bracing - 3 pieces (2in x 34.75)
                  2 pieces (0.75in x 14in)
6 inch Areoport from BAP. Port is about 16.75 from flare to flare.
Subwoofer is Skar ZVX-12. I believe subwoofer displacement is 0.15
Magical number is 1728 or the result of multiply 12 by it self 3 times. Or 12 x 12 x 12 = 1 cubic foot :) we will use this a lot.
Your gross volume is 14.5 x 35.5 x 19 / 1728 = 5.66 cubic foot
Your net internal volume is calculated by your internal dimensions, factoring in your double baffle, and subtracting any bracing, port volume, or other displacements like your subwoofer.
The internal volume will equal 13 x 34 x 16.75 / 1728 = 4.28 cubic feet
These other displacements can be split up into the following: Bracing, port, subwoofer, misc.
  • Bracing: You said you have 2 x 34.75 (that is impossible it must be 2 x 34 unless you gave the wrong outer dimensions...35.5 - 0.75 - 0.75 = 34" internal... not sure on that) Lets call this piece 2 x 34 x 0.75 thick / 1728 = 0.0295 x 3 pieces = 0.089 cubic feet of bracing
  • Bracing 2: Another piece of bracing that is 0.75 x 14 x 0.75 inch thick I assume ( again this has to be 13" long since your internal dimension is exterior minus the two faces thickness... 14.5 - 0.75 - 0.75 = 13... ) Lets call this piece 0.75 x 13 x 0.75 / 1728 = 0.0046 x 2 pieces = 0.009 cubic feet of bracing
  • Port: Area of a circle is Pi * r^2, volume of a cylinder is Area x height or Pi * r^2 * Height. Your aero port has an internal diameter that is barely under 6 inches (BAP has it labeled as 5.915) but for all assumptions sake we will call it 6". Pi * 3^2 * 16.75 = 0.27 cubic feet of port displacement ( since you have some flare inside your box this could be a little under your actual port volume, so you could round up to .3 to be safe - shouldn't matter that much )
  • Subwoofer: You said it was 0.12 cubic feet of subwoofer displacement.
Total displacements are equal to: 0.089 + 0.009 + 0.3 + 0.12 = 0.518 cubic feet of displacements
Your net internal volume is calculated by subtracting total displacements from internal volume as follows: 4.28 - 0.518 = 3.767 cubic feet of internal volume
Just now, BiGSt3v3 said:
Thanks for the lesson man<img src="> You are a life saver!
Np, questions are always welcome here!
  • Who's Online   0 Members, 0 Anonymous, 520 Guests (See full list)
