First off, you have to make sure you upgrade from a stock alternator to a high output alternator and get a couple or few extra batteries and run a big 3. Because on a factory set up that amp will distort more so and drop too low in voltage and give out after a while and you will be stuck with a broke amp and possibly damaged or worn out voice coils on your subwoofers from clipping. You have to handle that first. Have you covered this? And if so, what’s your budget on subwoofer(s)? I was about to run a taramps md8000.1 and I run a 390 amp alternator and a regular battery under the hood and big 4 upgrade and 2 extra 119ah agm batteries in the back. You have to upgrade your alternator and get more batteries to run that amp properly without complications.
:guido:
