HELP: Wasted Money on DD1 & CC1 combo ?
Hi Guys so we all know what these two are used for did I waste my money  ?
Plan on using Taramp HD3000.1 for my subs
Taramp DS800X4 for my doors
The DS800X4 only has a switch  High, Low pass or Full Range. No crossover settings to fine tune. - CC1 not needed correct ?
The HD3000.1  also only has Highpass 10hz to 80hz  and a Low Pass of 80Hz to Full  Confusing ??
Besides setting gains is the CC1 useful to me in any way ?
My Build log :
http://www.stevemeadedesigns.com/board/topic/170934-dragonmobile-re-audio-2300rms-stealth-build-08-focus/
Current System
2020 Ford F-150 XLT Supercrew
Audio Control Epicenter
Audio Control LC7i
Taramp PRO 2.6 DSP
Taramp DS4x800 - Highs
Taramp HD3000.1  Mids
Taramp MD5000.1 Bass
8 x DS18 6.5 Pro x6m - mids
2 x Soundsteam SST-05 Bullet Tweeter
2 x DS18 TW220 Super Tweeters
4 X SkarAudio EVL-8  BASS
Big 3
Yellow Top
Yes it is
Those crossovers on those amps leave a lot to be desired, to say the least. You'll likely want to add a simple electronic crossover of sometype. Maybe even a DSP.  Especially on the stereo amplifier, IMHO the cross overs sound "hot" to me if that makes sense. Some folks say that it provides all they need and it is fine. But I think it's a dirty dirty little motherfuker.
Now yes it's an added expense, but I think your after a little more than average/newb/Budget results. I'm basing that off of the purchase of the dd1 & cc1 combo. Another $200+ sounds like it sucks, but it's going to make your shit better and that's fun.
Oh and fuck, yes  lol
Even with out the external 3 way or 2 way crussiver / DSP, you still will utilize the cc1.
You want to set your crossover exact, correct? Not guess at were 63 or 70hz down is.
Also if you want to utilize that infrasonic/hpf on that bass amp, you will want to be exact on that, cuzz you can really kill your low end in a guessing game with that setting.
Same as your 4 channel, IMHO that thing needs processing. The taramps are good at raw power, but thier stereo amps need processing cuzz they are harsh.
If i understand you guys I can use it on the bass amp and just add some processing for the stereo amp  ?
Recommendations?
My Build log :
Current System
Audio Control LC7i
Taramp PRO 2.6 DSP
Big 3
Yellow Top
I dont know if this matters on the front doors im using the sundown 6.5 components that has its own crossover.
On the rear doors I'm using the sundown 6.5 coaxials
Can someone recommend an external crossover  for under $200
My Build log :
Current System
Audio Control LC7i
Taramp PRO 2.6 DSP
Big 3
Yellow Top
  • Who's Online   0 Members, 0 Anonymous, 993 Guests (See full list)
