kingcobb Posted May 16, 2020 Report Share Posted May 16, 2020 I just got the Deaf Bonce Machete MA 80.4 and I want to know how to set the crossover to work as a bandpass filter. It has a crossover setting for HPF, Full, and LP/BP. which setting should it be on to work as a bandpass filter Link to comment Share on other sites More sharing options...
1point21gigawatts Posted May 16, 2020 Report Share Posted May 16, 2020 Just set your mids and highs amp on hpf and set the hz to 75 and all frequencies 75hz and up will pass. Then set your subwoofer(s) amp to lpf, if it doesn’t give you that option then it’s already automatically set to lpf, and set the hz to 80 and set your subsonic or infrasonic filter to about 5hz below what your enclosure is tuned to and every frequency from that and 80hz will pass. “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.” Link to comment Share on other sites More sharing options...
