Sub Woofer and Box Suggestions for Truck
12V71
Not really happy with the performance of these old 12s and want to do something new. All Input is appreciated for a large extended cab truck.
Notes:
SQL focused
Budget 700 for subs
Power 1000 RMS at 2 ohm (amp can not run at 1 ohm and not buying another amp)
Need to face subs in a way that can accommodate the amps
Facing Back is the best current sound (tried forward, up, down, left, right)
Really would like 4 10s they have been better to me in similar applications
Picture of space
MAX dimensions included with proposed design
I have allowed an additional 3" on each side for ports
4 minutes ago, 1point21gigawatts said:
You’re not happy with you subwoofers and enclosure because of the way it’s facing. Face the subwoofers up and you will smile.
I did face them every way possible and this works the best for them,.
I would like to start over with new subs and new boxes
open to any configuration that will work the best,
last 4 10s in a truck i had was facing up and ports to the side. it rocked, wish i could get 4 old school boston pro series
That’s what I’d recommend, subs up, ports facing each side. Getting new subwoofers will do very little for you when it comes to improvement. Building a better enclosure is the main thing you need to worry about for any type of output gain if you don’t want to upgrade your amp. There’s no need to upgrade your subwoofers if you’re not upgrading your amp. Pointless and there will be minimal gain. The enclosure if done correctly will make that system sound twice as loud and twice as good.
:guido:
I agree with you 100%
The reason for new subs and new boxes to replace what is in there is a value reason for one.
I can get the least total cost out of this deal by the sale of the current set.
another point would not build a custom box for even a new set of what is in there now . no chance of repurchasing the same subs
I can make anything,
these fit the budget what do you think?
Skar 10-inch Dual 4 Ohm Voice Coil Configuration
Peak Power: 1,200 Watts
RMS Power: 600 Watts
Competition Grade Pressed Paper Cone
High Roll Foam Surround
Advanced Air Flow Cooling System
2.5" High Temperature Copper Voice Coil
Motor Weight: 97 oz
Frequency Response: 28 - 300 Hz
Sensitivity: 82.5 dB
Fs: 39 Hz
Re: Dual 4 Ω
Qms: 6.08
Qes: 0.68
Qts: 0.61
Mms: 188.75 gr
Nref: 0.126%
Cms: 0.079 mm/N
Bl: 10.9 n/a
Vas: 11 L
Sd: 298.65 cm²
Xmax: 13.5 mm
  • Who's Online   0 Members, 0 Anonymous, 1752 Guests (See full list)
