When buying an AGM what specs are most important?
When buying an agm battery, which battery specs are most important? Cca hca ah?
I was told ah is the main thing the higher the better. But then i was told its all about how many amps it can produce..the higher the better.. so should i be looking at the ah cca or hca??
Thanks
Will the battery only be a secondary battery or will it be your starting battery under the hood?
If it's just a secondary battery, AH is what I'd be looking at. As it will be used for reserve capacity.
Starting batteries need cranking amps, cold cranking/hot cranking. So CCA and HCA will play a bigger role.
Its rear batt/secondary batt.
Thank you for your reply. I will just get the biggest ah batt i can get for the rear.
  • Who's Online   0 Members, 0 Anonymous, 4497 Guests (See full list)
