Im an idiot please help. T1D215 + a DES1000.1D
4 hours ago, Brandonblank said:
ok, sorry i think i understand what you saying. but i dont understand what you mean by fully regulated... my bad i dont mean to waist you time with noob questions lol <img src=">
i was talking about the power supply inside your amplifier, mybad i might have got carried away.
Both 1 & 2 ohm loads on your amp will provide 1000W, amps that make the same power at different impedances usually have a fully regulated power supply of some sort, basically don't clip your output & all is good.
I've never used those lyumi oscopes before but if it does its job correctly, you should be able to see voltage & distortion.
Ahhhhh, ok I got you. nah your good hhaha. your information is very helpful! thank you! Maby tomorrow if i can ill post a demo of my system and you can give me pointers if you want! but i think its sounding alot better considering i dont have a DSP and stock speakers and no DD1
that amp can run both your subs, but getting a more powerful amp, would be ideal... i wouldnt run 2 sub amps.  id just run 1 really powerful one
and heres how to set your amp gain.  the correct test tones (50hz for sub, 1khz for mids/highs) are at the very bottom
https://jlaudio.zendesk.com/hc/en-us/articles/204374120-Amplifier-Level-Setting-Guide
note.. set deck sub volume to 3/4.  that link doesnt mention it, but JLs amp manuals do
Alpine 9887, Oz 180CS, RF R500X1D, 12" RE SE
