7 minutes ago, 1point21gigawatts said:
Read this. People believe things when they hear it from reputable sources.
https://ddaudio.com/subwoofer-enclosure-design-bending-the-rules-maximize-output/
the design i just posted,. its honestly the best i could do and i actually had to increase my max dimensions which will make this super tight to get in the trunk. but anyways,. take a look, do you think this design will work? its got 2.3 net, its got 36 sq inches of port and its tuned to about 32hz..
4 minutes ago, akuma4u said:
im not looking to blame anyone. help is appreciated no matter what.
what i find is that people just have different opinions on enclosures and what works. port area is a big area where there are opposing opinions.
yes, i can build several boxes and test and this is what i will probably end up doing. will be costly but i guess i have no choice.
as for now,. i am trying to build the box 1point21gigawatts told me to , but since i am limited in space, the closest i could come up with is the following. mind you my max dimensions are 13.5 tall x 32 wide x 17 deep , i had to push it .25 in the width and .5 in the depth to get more airspace.. i will have to router the outer edges to slide this thing in .. it will be TIGHT.
maybe 1point21 can take a look and tell me what he thinks.. this is the BEST i can do with the space i have...
That would work. Since I factored in the impedance rise best case scenario instead of doing port velocity calculations on 2000 rms. That enclosure would work just fine. It would have good bandwidth and good output. I like it.
:guido:
praise the lord.
i shall get this made.
all i need now... is a cut sheet/blueprint so i can pass it to my builder. can you assist me with that?
5 minutes ago, akuma4u said:
praise the lord.
Yes.
:guido:
awesome, thanks <img src=">
You are welcome. Question though, have you considered an aero ported enclosure? I was wanting to do a slot ported strictly spl enclosure on my application but, I decided to do a musical aero ported enclosure instead because it would have spl and be musical, have a wider bandwidth, more efficient, a better air flow and easier to design and build. Even though I could design and build a complicated and difficult enclosure, easier is always better.
:guido:
im open to anything that will work in my max dimensions and the u12 and my custom zv3 12..
max dimensions 13.5 tall x 32.25 wide x 17.5 deep
i did have a builder try to do a aero ported box but it didnt work out..
you can try and see if it will work i think a 6 inch aero port is needed .. if not the slot port is fine..
What’s more important to you, sounding loud or sounding good? Are you more geared towards a system for everyone else to hear and like or a system for you to hear and like? Which means more?
thats a good question. im kinda torn between the two. however im leaning towards LOUD. I love the feeling of my face and body being impacted by the bass.. the physical sensations.
In this application since it isn’t a wall or something like that, an aero port would be louder and sound better. The ported enclosure I designed for myself was strictly spl because it was designed with a lot of port area and bandwidth wasn’t something I cared about when designing it. I could use a lot of port area in that build because the enclosure only being about 4.6 cubes after displacements on around 6000-8000 rms after rise. But I decided to change to an aero port because in most regular applications an aero port is better and louder because air flows better through a tube than a rectangle or square and the response is better because of that too. But on that spl slot ported enclosure I designed would probably be louder than the aero ported one I designed but not sound nearly as good. But when it comes to your build, an aero port is the best way to go, no doubt.
:guido:
I don’t even know why I asked that stupid question about what’s more important to you. I’m getting tired. Lol! I’m about to go to bed. Think about what type of enclosure you want me to draw up for you. Do some research on both and comparisons and then we can touch base tomorrow.
:guido:
  • Who's Online   0 Members, 0 Anonymous, 1546 Guests (See full list)
