Question about RCA's and remote wires
Dafaseles
Kind of a newb question, I know, but I've never installed more than 2 monoblock and 1 4 channel amplifier in the same build before. So yeah, by definition, I'm a newb to this size build.
Regarding the RCA's. I have an Audio Control Three.2, so head unit directly into those inputs. Sub out to 1 Sundown Audio SALT 4 input, then output on the first amp to input of the second amp, correct?
Now the 3 4 channel amps is where my question is. The Three.2 has a front out, and a rear out. What is the best way to connect the Three.2 to 2 JL Audio JX400.1's and 1 Cresendo Symphony S4? Should I get one of those RCA distribution blocks, or is there a more preferable method? I don't use the fade or balance functions ever, if that matters in installation.
And as far as the remote wire. I assume I'm going to need a relay running 5 amplifiers. I'm also going to be using a TM1, a OM1, and VM1. Running those as well, will 1 relay work? Any recommendations on a relay you like?
Any help will be... well... helpful.... and greatly appreciated!
Not sure I understand fully but I’ll answer to my best knowledge of what you mean. You need to have a pair of rca Y cables coming straight from your eq front output should split signal cheaper than buying a distribution block. So1 rca to sub, 2 rca splitters from front to 2 jx 400s and rear rca’s to symphony if in 2channel mode. If your symphony is in 4 channel mode you’ll have to split the rear channels with 2 more splitters to have 4 channels. I hope this helps 👍
That makes sense. Thanks man
13 minutes ago, Thatcarkidd said:
Not sure I understand fully but I’ll answer to my best knowledge of what you mean. You need to have a pair of rca Y cables coming straight from your eq front output should split signal cheaper than buying a distribution block. So1 rca to sub, 2 rca splitters from front to 2 jx 400s and rear rca’s to symphony if in 2channel mode. If your symphony is in 4 channel mode you’ll have to split the rear channels with 2 more splitters to have 4 channels. I hope this helps <img src=">
  • Who's Online   0 Members, 0 Anonymous, 366 Guests (See full list)
