Dafaseles Posted August 14, 2020 Report Posted August 14, 2020 Kind of a newb question, I know, but I've never installed more than 2 monoblock and 1 4 channel amplifier in the same build before. So yeah, by definition, I'm a newb to this size build. Regarding the RCA's. I have an Audio Control Three.2, so head unit directly into those inputs. Sub out to 1 Sundown Audio SALT 4 input, then output on the first amp to input of the second amp, correct? Now the 3 4 channel amps is where my question is. The Three.2 has a front out, and a rear out. What is the best way to connect the Three.2 to 2 JL Audio JX400.1's and 1 Cresendo Symphony S4? Should I get one of those RCA distribution blocks, or is there a more preferable method? I don't use the fade or balance functions ever, if that matters in installation. And as far as the remote wire. I assume I'm going to need a relay running 5 amplifiers. I'm also going to be using a TM1, a OM1, and VM1. Running those as well, will 1 relay work? Any recommendations on a relay you like? Any help will be... well... helpful.... and greatly appreciated! 2011 Chevy Silverado under construction My build log here. Check it out!
Dafaseles Posted August 14, 2020 Author Report Posted August 14, 2020 I'll just bump this once. 2011 Chevy Silverado under construction My build log here. Check it out!
Thatcarkidd Posted August 14, 2020 Report Posted August 14, 2020 Not sure I understand fully but I’ll answer to my best knowledge of what you mean. You need to have a pair of rca Y cables coming straight from your eq front output should split signal cheaper than buying a distribution block. So1 rca to sub, 2 rca splitters from front to 2 jx 400s and rear rca’s to symphony if in 2channel mode. If your symphony is in 4 channel mode you’ll have to split the rear channels with 2 more splitters to have 4 channels. I hope this helps 👍
Dafaseles Posted August 14, 2020 Author Report Posted August 14, 2020 That makes sense. Thanks man 13 minutes ago, Thatcarkidd said: Not sure I understand fully but I’ll answer to my best knowledge of what you mean. You need to have a pair of rca Y cables coming straight from your eq front output should split signal cheaper than buying a distribution block. So1 rca to sub, 2 rca splitters from front to 2 jx 400s and rear rca’s to symphony if in 2channel mode. If your symphony is in 4 channel mode you’ll have to split the rear channels with 2 more splitters to have 4 channels. I hope this helps <img src="> 2011 Chevy Silverado under construction My build log here. Check it out!
