Calculating port area using xmax
Ari12
Goodday all.
Am trying my hands on building a box for my american bass xfl1222 sub. I've found a post about this using xmax for port area but it was just to much to soak in so am making a new 1. I have 2.5net to work with max,and i want to tune to 32hz. I can always use winisd or 12v to get the port length. I used a site called carstero online calculator an entered the xmax an it said a minimal of 12.5sq" per cube. Am more looking for what is that exact figure for best deep loud bass performance you know and i dont want to use the 12-16 "general rule".
Can someone give me a figure that will work?
Sub- american bass xfl1222
Xmax- 17.5mm
Tuning 32hz
Power- roughly 1800-2000rms wired to 1ohm
Thanks in advance.
That port area calculator factoring in xmax can’t be used because that calculator doesnt factor in net volume or rms. It told me the minimum port area I needed was 115sq” on a round port and the enclosure is 4.5 cubic feet. That’s super wrong. But in your case, that calculator was correct. But I would recommend about an inch and half more per cubic foot.
:guido:
So 14sq" per cube for that sweet spot?
Also, is winisd and 12v accurate for giving port lengths? I noticed that their about a .25" different, but that shouldn't be audible correct?
  • Who's Online   1 Member, 0 Anonymous, 875 Guests (See full list)
