2 15" ZV5s build, best amp and electrical?
Hey yall! Any help is appreciated, as the title implies I wanted to build a system with 2 15" sundown zv5s. They will be going into a full size SUV and currently I have down a 320 amp (220 idle) alternator with 2 positive runs of GP car audio's 2/0 AWG (OFHC) and using the frame as a direct ground. My question starts with what I should feed them with, I had my eye on the SALT 6 amplifier with the original intention of running it at 2 ohms for efficiency reasons but is it worth it to run it at 1 ohms and will the subs take close to 7K watts rms? or is it just better to run it at 2 ohms and feed the subs a little over 4000w rms? What recommendations do you have and what lithium battery is the best to run in this setup? thanks!
Them subwoofer would want more than a salt 6 at 1 ohm. You are forgetting about impedance rise. Most people that use 2 zv5’s on a salt amp use the 8k. What brand of alternator do you have?
:guido:
Wait so they take more power?? they ae rated for 2000W rms each and they take double that? my alternator is a Pure power Hairpin by Tucson alternators. shop in arizona with good feedback. So what could be best then? a salt 8 at 1 ohm a salt 12 at 2 ohms or 2 sae3000ds strapped? im going for efficiency to make up for the weak alt
A salt 8k at 1 ohm and get a lithium battery. That alternator is straight. You just need some more battery reserve, lithium. What’s your price range on a battery?
:guido:
oh ok, for a batteries 1000-1500 I know limitless lithium discontinued the 45ah what could be equivalent?
The cyber 6k.
:guido:
