Sundown Salt 6k fuse rating
josephj86
3 minutes ago, josephj86 said:
Ok thats cool another thing is I've seen it on the dyno put out 7977rms will this pop the fuses if I fused @600amp? I'm just trying to make sure nothing goes wrong
No, it shouldn't. I'm sure that video you saw, they had it fired with 600 amps as well. The cool thing about the SALT amps is the salt stands for Sundown Audio Low voltage Technology. They don't use as much power as other amplifiers that state the same rms. That's why I got 2 SALT 4's for my build!
Oh and another run ive seen the amp do 9027 rms @ 1ohm uncertified run to clippin will this be a problem if im fused @ 600amp
Also, take into account, I'm assuming you're referring to the Sundown Unofficial videos, they used the the single 1/0 input to dual 1/0 input in they're amplifier inputs. It does help with the current draw and output. Not a whole hell of a lot, but it does matter
  • Who's Online   0 Members, 0 Anonymous, 1755 Guests (See full list)
