international_j Posted November 30, 2020 Report Posted November 30, 2020 Hi Guys, I am new here... I would give a detailed introduction but let me keep it short by saying I'm 100% a JL Audio fan! Anyways, to the help needed. My amp keeps cutting out and alternating channels at certain volumes. If I keep the volume low enough all speakers play but if I play it too loud (which isn't even that loud) only one channel will play while the other channel cuts in and out. My amplifier flashes yellow (JL HD600/4) so I cut it down and it immediately goes back to green. I suspect it's my DSP....I have a Mosconi DSP that I purchased brand new (6to8 Aerospace). The reason I believe it's the DSP doesn't make a ton of sense but hear me out. It only does this while connected to a portable source (my phone). I can play the FM radio and Sirius at any volume I want with no issues, but any portable source has a negative effect. Meanwhile my subwoofer doesn't miss a beat. Any ideas? I am desperate for a fix!
Dafaseles Posted November 30, 2020 Report Posted November 30, 2020 Try getting some RCA's to headphone Jack, or if you have an iPhone, RCA's to however you can manually connect it to the RCA's, then connect your phone directly to the amp. See how that plays. If it plays fine, try it from the head unit with the DSP out of the equation. How do you hook your phone to the head unit? Blue tooth or otherwise? 2011 Chevy Silverado under construction My build log here. Check it out!
international_j Posted November 30, 2020 Author Report Posted November 30, 2020 I hook up my the devices using both bluetooth and usb... both same result. Maybe it has something to do with the Sync (Lincoln MKZ). I will try the RCA idea but I fear I will have the same result. I will also take the DSP out of the equation as you suggested and see if that helps!
Dafaseles Posted December 1, 2020 Report Posted December 1, 2020 Basically, isolate your equipment until you find the culprit 2011 Chevy Silverado under construction My build log here. Check it out!
