crownvictoria31 Posted December 12, 2020 Report Posted December 12, 2020 I am running 4/0 gauge excellence welding cable on my set up. From big 3 upgrade to a secoundary battery in trunk. I am currently useing 250 amp fuses from alternator to battery and 250 amp from front battery to rear battery. Is 250 amp fuse the right size or should i up it to 300amp or more?
Dafaseles Posted December 12, 2020 Report Posted December 12, 2020 Well, 4/0 welding cable is rated for about 400 amps so in theory, you could up the fuse size and still be safe. But I say if you're not blowing fuses, I'd leave it alone 2011 Chevy Silverado under construction My build log here. Check it out!
crownvictoria31 Posted December 12, 2020 Author Report Posted December 12, 2020 I am not blowing fuses. I guess im good at 250 then. I thought it would just make a difference in power transfer. Thanks brother
