Need help with amp and subs
never installed a big sound system to a car but i found alternator with 12v and 14v theres one each 200amp with 2 year warranty the volt i need to get is around 14.4 to 14.8 around like that right but which one is actually needed 12v or 14v lol abit dumb question i am not gona install this everything i got people who can.
12v and 14v alternators are usually the same. It's a 12v system that needs to charge around 14.7v.
200 amps, you're going to need 2. Going to have to get a dual alternator bracket made
You shouldn't mix lithium and AGM. They have a different discharge and charge rate, and they rest at completely different voltages. It'll just cause problems.
400 amps of charging and 1 100ah lithium should be more than enough.
Well, it sounds like it's going to be pretty cool. You should do a build log on here
