frequency range vs response
31 minutes ago, Dafaseles said:
Are you talking about your sub amp or highs amp?
I'm sorry I'm talking about about my subs... Those are the response / range levels of my subs... I'm trying to figure out how low they actually safely go.. and how high they can safely go
All that changes once you put them into an enclosure.
Usually, people tend to set their low pass filter to 80-90 hz and their high pass filter, or subsonic filter, to half an octave below the tuning of the enclosure
My subs recommended tuning is 32hz and my box is actually a prefab tuned to 32 hz... Let's say I put a -3db test tone on... How low can they handle it? Cuz that seems to me where I would want to set my subsonic at..
If the box tuning is 32, one whole octave is half that (16). Half of 16 is 8. 16+8=24. Slo I would set it at 24. And if everything is set correctly, a -3 db test tone at 24 hz.... no clipping.... you're subs will be fine. Though I don't think I'd recommend just blasting test tones at your subs. Unless you're competing
How high can my subs go? 250 or 400??? frequency response vs range..
So those parameters are usually calculated with the speaker being free air. All those things change once the speaker is put into an enclosure. But usually a 6.5" or 8" can reproduce sound above 80hz better and more efficiently that a huge subwoofer can. That's why we usually set our low pass filter below 100hz, the vast majority of the time, 80-90 hz
  • Who's Online   0 Members, 0 Anonymous, 1052 Guests (See full list)
