Why use 40hz test tone to set gain when amp crossover is set at 80hz?
I set the gain on my amp using a 40hz -5db test tone.
I open a song in audacity, peak amplitude is -0.8db.
I apply a 40hz LPF in audacity and make sure the peak amplitude is below -5db.
But then I realized the LPF on my amp is set to 80hz not 40hz.
If I apply a 40hz LPF in audacity, peak amplitude drops from -0.8db to -4.8db.
If I apply a 80hz LPF in audacity, peak amplitude drops from -0.8db to -2.9db.
Just trying to wrap my head around why I should use 40hz test tone to set my gain instead of a 80hz test tone.
40 hz is said to be the middle ground between 80 hz and 20 hz. It's only to simplify things. That being said, i know plenty of people who will actually set their gains with a sweep, rather than a test tone. But, to my knowledge, you can't do that with a DD1, you have to use an oscilloscope
  • Who's Online   1 Member, 0 Anonymous, 1306 Guests (See full list)
