what would you get with this amp to hit loud and low
2 hours ago, kalilac619 said:
One of my amps is out for repair so I’m only clamping about 800 watts a sub….best numbers so far is a 158.22 at the headrest in MECA and 160 even sealed on the dash
Do you think the crossfire xt3 18 would be worth upgrading to over the c7 18 on my taramps smart 3 3k at one ohm?
It's definitely rated for the power, you wouldn't need to turn back the amp.  The XT3 looks like an epic beast on paper.
55 minutes ago, Dafaseles said:
Looks bad ass!
I don't mean to hijack dudes thread, but what did you use for those braces? I need some
Looks like threaded steel rod with threaded flanges similar to these:
https://www.lowes.com/pd/Mueller-Proline-1-in-dia-Black-Iron-Floor-Flange-Fitting/1000217679
1 hour ago, Dafaseles said:
Looks bad ass!
Threaded steel pipe from Home Depot….I just painted it black
2000 Suburban 6 runs of 2/0
12 timpano audio mids,6 timpana audio tweets and 1 timpano compression horn per door
8 banks of blue Maxwells + 260ah of Yin Long LTOs
2 370 Amp Autotech Alts
mids amps 2  Crescendo Skyway 3ks
Tweet amp Crossfire 2000.4
sub amp: 4 Crossfire XT 8ks
Subs: 8 18 in Crossfires in a 4th order
Best Scores at events…
161.6@38hz DBdrag  sealed on the dash… 162.54 outlaw…161.14 Meca headrest
Not for that power….the C7s are under rated beasts and could easily be rated at 2k-2.5k and still not have issues….xt3s are under rated as well and could easily be rated higher
Thanks.  Do they make recones for the c7 18 v3?
I believe so….I’ll have mine on 2 16ks…. I’ll let you know Lol
Do you think id be in the high 140's db wise in a 7 cubic foot net tuned to 34 hz on the 3k taramps at 1 ohm with a 8 inch aero port (its adjustable too) in a 2019 nissan versa sv trunk sealed to get all pressure in the cab with a 350 amp alternator?
  • Who's Online   0 Members, 0 Anonymous, 1665 Guests (See full list)
