TechnoBass Posted June 23, 2021 Report Posted June 23, 2021 Like the title says...I'm looking for the best amp, preferably JL or Kicker if possible. The sub is dual 2-ohm 300W RMS / 150w per coil. I'm having a hard time finding a mono 300W @ 1-ohm. If there is anything else that is 300W @ 1ohm, let me know. Thanks.
Arthur79 Posted June 23, 2021 Report Posted June 23, 2021 Kicker CXA400.1 - 400w RMS @ 1 Ω Rockford Fosgate Power T500X1br - 500w RMS @ 1Ω Rockford Fosgate Punch PBR300X1 - 300w RMS @ 1 Ω Cerwin Vega HRPM350.1D - 350w RMS @ 1 Ω There aren't a a ton of 300 watt @ 1 Ω amps these days, seems like your options are either run a 2 Ω woofer or entry level power at 1 Ω is around the 500w range. No reason you can't get a 500w amp and dial your gains back a bit. Pretty easy to do with the SMD DD-1, just set your overlap high and you should be good. If you had a 2 Ω woofer there are some good options out there from JL, Kicker, Rockford and Audio Control.
Goomz Posted June 23, 2021 Report Posted June 23, 2021 Or find an 800 ish watt rms amp @ 2 ohms and wire it to 4ohms into the amp. Should be around 3-500 watts @ 4. instagram.com/installsbypat
Arthur79 Posted June 23, 2021 Report Posted June 23, 2021 56 minutes ago, Goomz said: Or find an 800 ish watt rms amp @ 2 ohms and wire it to 4ohms into the amp. Should be around 3-500 watts @ 4. Good point, it's probably easier to find amps that will do 300ish at 4 Ω JBL Club A600 - 350w RMS @ 4Ω Alpine S-A60M - 330w RMS @ 4Ω MTX Thunder 500.1 - 300w RMS @ 4Ω Kenwood Excelon X501-1 - 300w RMS @ 4Ω Pioneer GM-DX871 - 300w RMS @ 4Ω Sony XM-GS100 - 330w RMS @ 4Ω Kicker 46CXA800.1T - 300w RMS @ 4Ω Rockford Fosgate R2-500X1 - 300w RMS @ 4Ω CT Sounds M750.1 - 350w RMS @ 4Ω at 12.8v The list for 300ish @ 4Ω goes on.
Goomz Posted June 23, 2021 Report Posted June 23, 2021 2 minutes ago, Arthur79 said: Good point, it's probably easier to find amps that will do 300ish at 4 Ω JBL Club A600 - 350w RMS @ 4Ω Alpine S-A60M - 330w RMS @ 4Ω MTX Thunder 500.1 - 300w RMS @ 4Ω Kenwood Excelon X501-1 - 300w RMS @ 4Ω Pioneer GM-DX871 - 300w RMS @ 4Ω Sony XM-GS100 - 330w RMS @ 4Ω Kicker 46CXA800.1T - 300w RMS @ 4Ω Rockford Fosgate R2-500X1 - 300w RMS @ 4Ω CT Sounds M750.1 - 350w RMS @ 4Ω at 12.8v The list for 300ish @ 4Ω goes on. Yep and less effort out of the amp and electrical too instagram.com/installsbypat
